주요 콘텐츠로 건너뛰기
Reactivate USB Port after electrical overload
필요한 것
    • Both USB ports of a MacBook were dead after a shortage or overload on a Ramps Board that was connected to the Mac via an Arduino Board.
    • Normally Mac OS shows a message that tells you that the USB device got deactivated due to a power surge on that port. In this case the message wasn't displayed. It was later displayed after a reboot. Anyway both USB ports were instantly dead.
    • Here and there in the internet people advise to perform a SMC reset. That was done but didn't help. But you should try the SMC reset first.
    • Make yourself familiar with the pinout of your USB cable. Find the ground (GND) and measure with a multimeter if there is still an connection between both ground pins of the USB ports.
    • Check that there is really no power between ground and the +5V pin of the USB cable.
    • Double check that you have a proper working, good quality desktop power supply. https://en.wikipedia.org/wiki/Power_supp...
    • Set it to +5V DC and double and triple check the power and the polarity with a multimeter.
    • Connect ground of the USB port with ground of the external desktop power supply.
    • Maybe you can use just a usb cable but I preferred to use a cable with a device. I used an FTDI breakout board from sparkfun because there the pins are relatively good accessible.
    • Supply the USB device (I suppose on the port that caused the problem) with 5V from the desktop power supply on the 5V pin of the USB plug.
    • The LEDs on the FTDI light up and it is recognized by the Mac.
    • For whatever reason the second USB port got reactivated, too. It works without the need to provide the connected USB device with external power.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Axel
회원 가입일: 04/18/17
112 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 1,606
