주요 콘텐츠로 건너뛰기
Realigning 12-Inch Bionaire Fan Metal Coil
필요한 것
  1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: 1 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: 1 단계, 이미지 2개 중 2개
    • Unlock all of the tabs holding the fan cage together.
    • Carefully pull off the cage.
  2. Realigning 12-Inch Bionaire Fan Metal Coil: 2 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
    • Blade may be sharp so watch out!
    • Cautiously remove the blade from the hinge.
    • Put the screws in a cup so you don't lose them!
  3. Realigning 12-Inch Bionaire Fan Metal Coil: 3 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 3 단계, 이미지 2개 중 2개
    • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
    • Pull off the back cage from the engine holder.
  4. Realigning 12-Inch Bionaire Fan Metal Coil: 4 단계, 이미지 1개 중 1개
    • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
  5. Realigning 12-Inch Bionaire Fan Metal Coil: 5 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 5 단계, 이미지 2개 중 2개
    • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
  6. Realigning 12-Inch Bionaire Fan Metal Coil: 6 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 6 단계, 이미지 2개 중 2개
    • Pull of the black knob by rotating the knob counter-clockwise.
    • Pull down the black cover all the way.
    • The coil may pop out after removing the cover.
  7. Realigning 12-Inch Bionaire Fan Metal Coil: 7 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 7 단계, 이미지 2개 중 2개
    • Take out the gold metal spring.
    • Realign the metal coil into designated space.
    • Push the coil in with some force so it rests perfectly in the space.
    • To make placing the coil back in more easier, use the screwdriver!
  8. Realigning 12-Inch Bionaire Fan Metal Coil: 8 단계, 이미지 2개 중 1개 Realigning 12-Inch Bionaire Fan Metal Coil: 8 단계, 이미지 2개 중 2개
    • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
    • This can be a frustrating step. Be patient!
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hemish Patel
회원 가입일: 09/29/15
231 평판
안내서 1개를 작성함
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 회원
CPSU-GREEN-F15S10G3
4 회원들
안내서 4개를 작성함
댓글 한 개
I have a fan It hum I have to spin the blade for it to start spin
Chris - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 3,936
