주요 콘텐츠로 건너뛰기
Realspace EC600 Office Chair Lift Cylinder Replacement
필요한 것
  1. Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: 1 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: 1 단계, 이미지 2/2
    • Position the chair so that you have access to the underside of its base.
    • Some of the parts will be coated in oil and can create a mess in your workspace.
  2. Realspace EC600 Office Chair Lift Cylinder Replacement: 2 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement: 2 단계, 이미지 2/2
    • Remove the spring retaining clip by lifting with the flathead screwdriver and sliding it off with your thumb.
    • Remove the washer that was underneath the clip.
  3. Realspace EC600 Office Chair Lift Cylinder Replacement: 3 단계, 이미지 1/1
    • Lift the base off of the lift cylinder.
    • The rubber bumper, washers, and bearings may fall off during this step.
  4. Realspace EC600 Office Chair Lift Cylinder Replacement: 4 단계, 이미지 1/1
    • Remove the rubber bumper, washers, and bearings.
  5. Realspace EC600 Office Chair Lift Cylinder Replacement: 5 단계, 이미지 1/1
    • Remove the lift cylinder cover.
  6. Realspace EC600 Office Chair Lift Cylinder Replacement: 6 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement: 6 단계, 이미지 2/2
    • Spray WD-40 around the base of the lift cylinder.
    • Loosen the cylinder off the chair by rotating it with the pipe wrench.
    • If you are having trouble rotating the the cylinder off, then wrap painter's tape around where you are rotating the cylinder.
  7. Realspace EC600 Office Chair Lift Cylinder Replacement: 7 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement: 7 단계, 이미지 2/2
    • Remove the old lift cylinder.
    • Press the new cylinder into the chair.
    • The ends of the cylinder will have oil on them so they may make a mess.
  8. Realspace EC600 Office Chair Lift Cylinder Replacement: 8 단계, 이미지 1/1
    • Push the lift cylinder cover onto the new cylinder.
  9. Realspace EC600 Office Chair Lift Cylinder Replacement: 9 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement: 9 단계, 이미지 2/2
    • Push the rubber bumper, washers, and bearings onto the lift cylinder.
    • The order should be from the chair to the rubber bumper, washer, bearings, and then the other washer.
  10. Realspace EC600 Office Chair Lift Cylinder Replacement: 10 단계, 이미지 1/1
    • Set the base over the lift cylinder and press it onto the cylinder.
  11. Realspace EC600 Office Chair Lift Cylinder Replacement: 11 단계, 이미지 1/2 Realspace EC600 Office Chair Lift Cylinder Replacement: 11 단계, 이미지 2/2
    • Place the washer at the end of the cylinder.
    • Slip the spring retaining clip onto the end of the cylinder.
결론
Finally, flip the chair back over and press down on the seat of the chair to make sure the cylinder is completely pressed in.
다른 3명이 해당 안내서를 완성하였습니다.
Patrick Kay
회원 가입일: 09/16/20
274 평판
안내서 1개 작성함
University of Memphis, Team S4-G20, Kim Fall 2020 University of Memphis, Team S4-G20, Kim Fall 2020 회원
UM-KIM-F20S4G20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 76
전체 시간: 2,150
