주요 콘텐츠로 건너뛰기
Reattaching the GEN 2 Wheelchair Foot Support
필요한 것
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 1 단계, 이미지 1/3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 1 단계, 이미지 2/3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 1 단계, 이미지 3/3
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: 2 단계, 이미지 1/1
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: 3 단계, 이미지 1/2 Reattaching the GEN 2 Wheelchair Foot Support: 3 단계, 이미지 2/2
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
결론
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
회원 가입일: 04/19/13
207 평판
안내서 5개 작성하였습니다
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 회원
CPSU-MANESS-S13S14G8
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 801
