주요 콘텐츠로 건너뛰기
Recharging A/C Refrigerant for 2016 Hyundai Elantra
필요한 것
  1. Recharging A/C Refrigerant for 2016 Hyundai Elantra, Recharging A/C Refrigerant for 2016 Hyundai Elantra: 1 단계, 이미지 1/1
    • Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
  2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 2 단계, 이미지 1/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 2 단계, 이미지 2/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 2 단계, 이미지 3/3
    • Find and pull the lever to the hood on the driver's side of the vehicle.
  3. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 3 단계, 이미지 1/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 3 단계, 이미지 2/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 3 단계, 이미지 3/3
    • Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
  4. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 4 단계, 이미지 1/2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 4 단계, 이미지 2/2
    • Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
  5. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 5 단계, 이미지 1/2 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 5 단계, 이미지 2/2
    • Shake the can well.
  6. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 6 단계, 이미지 1/1
    • Connect the refrigerant hose to the low-pressure port.
  7. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 7 단계, 이미지 1/1
    • Start the vehicle and turn on the A/C all the way on.
  8. Recharging A/C Refrigerant for 2016 Hyundai Elantra: 8 단계, 이미지 1/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 8 단계, 이미지 2/3 Recharging A/C Refrigerant for 2016 Hyundai Elantra: 8 단계, 이미지 3/3
    • While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
결론
To recharge your vehicle, follow these instructions in order.
Austin Meadowcroft
회원 가입일: 05/21/20
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 197
30일 전: 834
전체 시간: 9,107
