주요 콘텐츠로 건너뛰기
RedMax BCZ3050S Spark Plug Replacement
필요한 것
  1. RedMax BCZ3050S Spark Plug Replacement, Spark Plug: 1 단계, 이미지 1개 중 1개
    • Look for the black plastic cover with ridges on the top of the brush cutter. Your fingers should be enough to pull the plastic off, but you may use a flat head screwdriver instead.
  2. RedMax BCZ3050S Spark Plug Replacement: 2 단계, 이미지 1개 중 1개
    • Lift and separate the black plastic ridge covering from the spark plug..
    • Notice the spark plug still attached inside.
  3. RedMax BCZ3050S Spark Plug Replacement: 3 단계, 이미지 1개 중 1개
    • Use a 3/8 in wrench to grip and twist the spark plug counterclockwise until it loosens and take it out.
    • You can use slip-joint pliers to perform the removal of the spark plug if you don't have a wrench.
  4. RedMax BCZ3050S Spark Plug Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the new spark plug and twist it in a clockwise motion until it is tight.
  5. RedMax BCZ3050S Spark Plug Replacement: 5 단계, 이미지 1개 중 1개
    • Use the wrench or pliers and twist the spark plug in a clockwise direction to ensure a tight fit before placing the cover on top of the spark plug.
  6. RedMax BCZ3050S Spark Plug Replacement: 6 단계, 이미지 1개 중 1개
    • Attach the bottom of the plastic cover to the top of the spark plug.
    • Firmly push down on top of the spark plug with the cover. This is enough pressure to connect the new spark plug to the machine.
  7. RedMax BCZ3050S Spark Plug Replacement: 7 단계, 이미지 1개 중 1개
    • Once the cover is fully inserted, the repair is complete.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Saul Aceves
회원 가입일: 10/13/20
166 평판
안내서 1개를 작성함
1가이드 댓글
No, you use a spark plug socket to remove a spark plug.
Jose - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 32
전체 시간: 949
