주요 콘텐츠로 건너뛰기
RedOctane X-Plorer Auxiliary Port Replacement
필요한 것
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: 2 단계, 이미지 3개 중 1개 RedOctane X-Plorer Auxiliary Port Replacement: 2 단계, 이미지 3개 중 2개 RedOctane X-Plorer Auxiliary Port Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: 3 단계, 이미지 3개 중 1개 RedOctane X-Plorer Auxiliary Port Replacement: 3 단계, 이미지 3개 중 2개 RedOctane X-Plorer Auxiliary Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 4 단계, 이미지 3개 중 1개 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 4 단계, 이미지 3개 중 2개 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 4 단계, 이미지 3개 중 3개
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
결론
작성자
3다른 기여자 명과 함께
Riley
회원 가입일: 04/18/18
703 평판
안내서 7개를 작성함
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G1
3 회원들
안내서 9개를 작성함
1가이드 댓글
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 29
전체 시간: 1,463
