주요 콘텐츠로 건너뛰기
RedOctane X-Plorer Motherboard Replacement
필요한 것
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: 1 단계, 이미지 1/2 RedOctane X-Plorer Motherboard Replacement, Rear Case: 1 단계, 이미지 2/2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: 2 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement: 2 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: 3 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement: 3 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: 4 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: 4 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: 4 단계, 이미지 3/3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: 5 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: 5 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: 5 단계, 이미지 3/3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: 6 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, Keys: 6 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, Keys: 6 단계, 이미지 3/3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: 7 단계, 이미지 1/1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: 8 단계, 이미지 1/2 RedOctane X-Plorer Motherboard Replacement: 8 단계, 이미지 2/2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: 9 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: 9 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: 9 단계, 이미지 3/3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: 10 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: 10 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: 10 단계, 이미지 3/3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: 11 단계, 이미지 1/2 RedOctane X-Plorer Motherboard Replacement: 11 단계, 이미지 2/2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: 12 단계, 이미지 1/1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: 13 단계, 이미지 1/3 RedOctane X-Plorer Motherboard Replacement, Motherboard: 13 단계, 이미지 2/3 RedOctane X-Plorer Motherboard Replacement, Motherboard: 13 단계, 이미지 3/3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Riley
회원 가입일: 04/18/18
649 평판
안내서 7개 작성하였습니다
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G1
3 회원들
안내서 9개 작성하였습니다
댓글 한 개
Where can I but a replacement board?
Matthew - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 45
전체 시간: 2,432
