소개
If the motherboard becomes damaged, all other electronics must be removed first before you can access it. This guide will show you the steps necessary to access the motherboard.
필요한 것
Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
Gently lift up on the auxiliary port to remove it from the case.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
Lift up on the strum bar sensor board to remove it from the case.
Remove the two 7mm Phillips #0 screws.
Using your fingers, remove the black wire retainer.
Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
Lift the motherboard to remove it from the case.
다른 한 분이 해당 안내서를 완성하였습니다.
