주요 콘텐츠로 건너뛰기
RedOctane X-Plorer Rubber Button Strip Replacement
필요한 것
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 1 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 1 단계, 이미지 2개 중 2개
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: 3 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement: 3 단계, 이미지 2개 중 2개
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: 4 단계, 이미지 1개 중 1개
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: 5 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement: 5 단계, 이미지 2개 중 2개
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: 7 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement: 7 단계, 이미지 2개 중 2개
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: 8 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement: 8 단계, 이미지 2개 중 2개
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: 9 단계, 이미지 2개 중 1개 RedOctane X-Plorer Rubber Button Strip Replacement: 9 단계, 이미지 2개 중 2개
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
결론
작성자
3다른 기여자 명과 함께
Stephen Haning
회원 가입일: 09/30/21
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 368
