소개
The whammy bar spring can dislodge from its mounts causing the bar to lose tension. This guide will show you how to replace the whammy bar spring.
필요한 것
Remove the two 7mm Phillips #2 screws from the black wire retainer.
Pull off the black wire retainer.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
