주요 콘텐츠로 건너뛰기
RedOctane X-Plorer Whammy Bar Replacement
필요한 것
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 1 단계, 이미지 1/2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 1 단계, 이미지 2/2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: 2 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Replacement: 2 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Replacement: 2 단계, 이미지 3/3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: 3 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Replacement: 3 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Replacement: 3 단계, 이미지 3/3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 4 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 4 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 4 단계, 이미지 3/3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: 5 단계, 이미지 1/1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: 6 단계, 이미지 1/2 RedOctane X-Plorer Whammy Bar Replacement: 6 단계, 이미지 2/2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: 7 단계, 이미지 1/1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: 8 단계, 이미지 1/1
    • Using two hands, remove the spring from the plastic tabs.
결론
다른 3명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 04/18/18
175 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 81
전체 시간: 3,529
