주요 콘텐츠로 건너뛰기
RedOctane X-Plorer Whammy Bar Sensor Replacement
필요한 것
  1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: 1 단계, 이미지 1/2 RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: 1 단계, 이미지 2/2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Sensor Replacement: 2 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Sensor Replacement: 2 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Sensor Replacement: 2 단계, 이미지 3/3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Sensor Replacement: 3 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Sensor Replacement: 3 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Sensor Replacement: 3 단계, 이미지 3/3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: 4 단계, 이미지 1/3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: 4 단계, 이미지 2/3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: 4 단계, 이미지 3/3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Sensor Replacement: 5 단계, 이미지 1/2 RedOctane X-Plorer Whammy Bar Sensor Replacement: 5 단계, 이미지 2/2
    • Using one hand, remove the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Sensor Replacement: 6 단계, 이미지 1/1
    • Using two hands, remove the whammy bar sensor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Riley
회원 가입일: 04/18/18
649 평판
안내서 7개 작성하였습니다
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 21
전체 시간: 935
