주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Redmi A3 Screen Replacement
필요한 것
  1. Redmi A3 Screen Replacement, Remove SIM: 1 단계, 이미지 1개 중 1개
    • Remove the SIM slot so that it doesn't break when you take the phone apart
  2. Redmi A3 Screen Replacement, Heat the adhesive: 2 단계, 이미지 1개 중 1개
    • Heat the edges of the back cover and the area of the camera cover using your heat gun, heating pad, or hair dryer
    • If using a hair dryer, be careful, because it's obviously quite imprecise
  3. Redmi A3 Screen Replacement, Pry open the back cover: 3 단계, 이미지 1개 중 1개
    • Insert a thin piece of plastic under the back cover and pry it open by dragging the plastic around the edges and carefully under the camera cover
    • If the adhesive is too tough, heat it up again
  4. Redmi A3 Screen Replacement, Remove back cover: 4 단계, 이미지 1개 중 1개
    • Carefully remove the back cover of your phone
    • If the back cover is glass, it's better to use a suction cup or a piece of duct tape to avoid cracking
    • Remove the remaining adhesive using adhesive remover or by carefully scraping it off (I forgot to do that initially)
  5. Redmi A3 Screen Replacement, Unscrew frame: 5 단계, 이미지 3개 중 1개 Redmi A3 Screen Replacement, Unscrew frame: 5 단계, 이미지 3개 중 2개 Redmi A3 Screen Replacement, Unscrew frame: 5 단계, 이미지 3개 중 3개
    • Using a small phillips screwdriver, unscrew the frame of the phone
    • Be careful not to lose any of the screws
  6. Redmi A3 Screen Replacement, Remove frame: 6 단계, 이미지 2개 중 1개 Redmi A3 Screen Replacement, Remove frame: 6 단계, 이미지 2개 중 2개
    • The frame of your phone should come off fairly easily
    • CAREFUL! You probably know this already, but the lock button is the fingerprint sensor; don't forget to disconnect it.
  7. Redmi A3 Screen Replacement, Remove battery: 7 단계, 이미지 3개 중 1개 Redmi A3 Screen Replacement, Remove battery: 7 단계, 이미지 3개 중 2개 Redmi A3 Screen Replacement, Remove battery: 7 단계, 이미지 3개 중 3개
    • Disconnect the battery (you can do it with your fingers, I'm just using the screwdriver as a pointer)
    • This is a bit tricky: the orange sticker on the battery is separated into two parts labelled A (sides) and B (middle). Peel off the sticker and pull on A
    • Remove the battery with the rest of the sticker. Do not throw the sticker away
  8. Redmi A3 Screen Replacement, Disconnect screen: 8 단계, 이미지 2개 중 1개 Redmi A3 Screen Replacement, Disconnect screen: 8 단계, 이미지 2개 중 2개
    • There are two spots where the screen is connected, don't forget to unplug both cables
  9. Redmi A3 Screen Replacement, Remove screen: 9 단계, 이미지 2개 중 1개 Redmi A3 Screen Replacement, Remove screen: 9 단계, 이미지 2개 중 2개
    • Similarly to the back cover, heat the adhesive and pry the screen off the phone
    • If your screen is as badly cracked as mine, put duct tape all over it to avoid injury (I didn't do that)
    • Remove the remaining adhesive from the phone
  10. Redmi A3 Screen Replacement, Glue and connect new screen: 10 단계, 이미지 2개 중 1개 Redmi A3 Screen Replacement, Glue and connect new screen: 10 단계, 이미지 2개 중 2개
    • Carefully apply a small but substantial amount of phone adhesive around the edges of the phone. Make sure not to touch the front camera
    • Put the new screen on the phone
    • Connect the screen
결론
To reassemble your device, follow these instructions in reverse order. Do not forget that the back cover is also glued to the phone around the camera. It's recommended that you wait for several hours (preferably 48) for the adhesive to cure.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nicky C.
회원 가입일: 12/05/25
346 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 22
지난 30일: 140
전체 시간: 814
