필요한 것
take out the sim tray
unscrew the two pentalobe P2 screws under the phone
use a suction cup and a pryer to open the phone(Very Heavy!)
unplug the power cable. it should be attached just by pushing , so just lift it.
unplug the screen cable. they are ZIF connectors.
you can test the new screen here, just by plugging the new screen cable, then the power cable
unplug the button cable, also ZIFs.
remove the battery using a hard rubber spatula.(it's got handle like IPhone's, but with china quality)
pry from the left bottom side. NEVER from the right side, or you might damage a cable.
remove the remaining glue from the battery, and re-tape it inside the white lines with tapes like TESA 2mm.
unplug antenna wire running down right side of phone to bottom mainboard.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 7개
Where's the video? I can't find it on this page.
Redmi Note 4 lcd Jumper ways
Please!
Where can I find the replacement screen for this model??
The screen I ordered have the connectors the wrong place and I can't find any replacement screen with BOTH wires on the bottom …
you could buy a new screen in taobao
牛头与画像 -
