주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Redmi Note 9 Pro - Reboots, Power On flex Replacement
필요한 것
동영상 개요
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
  1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 1 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 1 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 1 단계, 이미지 3개 중 3개
    • Warm up the device to soften the adhesive.
    • Use plastic tools and a little isopropyl alcohol to separate the back cover.
  2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 2 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 2 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 2 단계, 이미지 3개 중 3개
    • Remove the Phillips screws that secure the motherboard cover.
    • Use a plastic opening tool to remove the cover.
  3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 3 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 3 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 3 단계, 이미지 3개 중 3개
    • Lift up the flex connector to disconnect the battery.
    • Remove the main cameras.
    • Remove the SIM tray.
  4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 4 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 4 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 4 단계, 이미지 3개 중 3개
    • Disconnect all flex cables:
    • Fingerprint sensor flex cable
    • Screen flex cable
    • Main flex cable
    • Coaxial antenna cable
    • Remove the Phillips screws securing the motherboard to the middle frame
    • Remove the motherboard.
  5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 5 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 5 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 5 단계, 이미지 3개 중 3개
    • Remove the Fingerprint sensor.
    • Remove the volume buttons plastic cap.
    • Use isopropyl alcohol to help remove the glued down flex cable.
  6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 6 단계, 이미지 3개 중 1개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 6 단계, 이미지 3개 중 2개 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 6 단계, 이미지 3개 중 3개
    • Use playing cards to remove the flex cable.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
197,078 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
333 회원들
안내서 1,477개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 53
지난 30일: 232
전체 시간: 8,211
