주요 콘텐츠로 건너뛰기
Redragon K552 Key Switch Replacement
필요한 것
  1. Redragon K552 Key Switch Replacement, Key Switch: 1 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement, Key Switch: 1 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement, Key Switch: 1 단계, 이미지 3개 중 3개
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: 2 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 2 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: 3 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 3 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 3 단계, 이미지 3개 중 3개
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: 4 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 4 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 4 단계, 이미지 3개 중 3개
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: 5 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 5 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 5 단계, 이미지 3개 중 3개
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: 6 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 6 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: 7 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 7 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 7 단계, 이미지 3개 중 3개
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: 8 단계, 이미지 3개 중 1개 Redragon K552 Key Switch Replacement: 8 단계, 이미지 3개 중 2개 Redragon K552 Key Switch Replacement: 8 단계, 이미지 3개 중 3개
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lyxander Blanco
회원 가입일: 03/19/22
187 평판
안내서 1개를 작성함
CSU Los Angeles, Team 6-2, Briggs Spring 2022 CSU Los Angeles, Team 6-2, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S6G2
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 48
전체 시간: 8,318
