소개
Esta guía te ayudará a reemplazar el RAM.
필요한 것
Afloja los tres tornillos Phillips que sujetan la tapa de acceso al extremo inferior de tu iMac.
Quita la tapa de acceso de tu iMac.
Usa tus dedos o la punta de un spudger para deslizar la lengüeta de plástico de la bandeja de RAM de la ranura RAM.
Bonjour, j’ai arraché la languette. Conséquence, elle est inutilisable et je ne peux pas retirer la barrette. Comment faire autrement ? Est-ce que cet outil peut être utile ?
Tira de la pestaña de plástico negro del iMac para expulsar el chip de RAM de su ranura.
Usa tus dedos para deslizar el chip RAM fuera de su ranura.
None. 4mb ram is too old to fit into any computer manufactured after like 1998.
@Brett
I suggest that you learn your unit symbols before you try to appear clever:
4mb == 4 milli bits
4MB == 4 mega bytes
nowsc was obviously meaning 4GB not 4MB, try not to be a dick.
Just for the records :
4 millibits are 0,000000004 MB
There was never any RAM in mb and the question states MB and nobody except you is talking of millibits.
You are also a dick if you try to spread “your knowledge” nobody has asked for
Take care to note which way out the RAM comes - there is a notch in each RAM and it is not centered, therefore either the notch will be on the left or to the right (depending on which way up you have your iMac). This will make it easier to replace the RAM without damaging anything.
If damaged the notch inside one pair of RAM slots, is it fixable ?
its not that hard to say that you can add up to 4GB sticks, bringing a total to 16GB
Para reensamblar tu dispositivo, sigue las instrucciones en sentido contrario.
다른 90명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 14개
My iMac 21.5-inch Mid 2011 has EMC 2428, but still directions turned out to be the same.
I replaced the memory in my MacBook Pro, and used the old cards (2x2GB) to fill out the 2 empty slots that apple left empty, doubled the memory of 2 machines for the price of one ^_^
So confused. I have an end 2429 and I ordered some memory hut its says notebook memory, do these machines use the same type of ram?
Thanks ifixit team, I did it. It is really piece of cake! Thanks again!
What's the real max capacity for the RAM?
16 Gb (4 x 4 Gb) DDR3 1333 MHz
16gb according to Apple but 32gb is no problem I would recommend using all identical sticks ie. same manufacturer/speed etc etc.
I have run 32gb for years in that machine With no issues.
Hi, can I add one Ram of 4MB and one of 8Mb?
You can but it’s not an ideal configuration
Hi, according to Mactracker the iMac 27 inch mid 2011 can have up to 32GB of RAM. Anyone tested this?
Absolutely I have 32gb and I have used that config since it was new
With EMC 2429 can I upgrade just two of the four RAM slots? ie I currently have 4x2 GB RAM (8GB total), can I replace just two if the ram chips with 4 GB chips so I end up with 2x4GB and 2x2GB (12GB total) installed? Many thanks
Yes, you can. As long as you are installing as a pair, you can replace two 2GB (2x2) with two 4GB (2x4).
Mikkif -
I think it would be ok to show what the position of the RAM should be when you insert it.
And leave the old RAM in. Adding RAM the easy way.
A Eensteen - 답글
I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
Wizbang FL - 답글
I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
gordonhamachi - 답글
