주요 콘텐츠로 건너뛰기
Refresh, Reset, Start-up repair from USB recovery media
동영상 개요
  1. Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 1 단계, 이미지 3개 중 1개 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 1 단계, 이미지 3개 중 2개 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 1 단계, 이미지 3개 중 3개
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
  2. Refresh, Reset, Start-up repair from USB recovery media: 2 단계, 이미지 3개 중 1개 Refresh, Reset, Start-up repair from USB recovery media: 2 단계, 이미지 3개 중 2개 Refresh, Reset, Start-up repair from USB recovery media: 2 단계, 이미지 3개 중 3개
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,841 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,454개를 작성함
3가이드 댓글
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - 답글
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - 답글
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 28
전체 시간: 5,963
