소개
If you forgot your password, or you want to delete all data, or you have problem with power on the tablet...
동영상 개요
- Make Surface turned off and plugged in.
- Insert the USB recovery drive into the USB port.
- Press and hold the Volume Down button, press the Power button in a short time.
- When the Surface logo appears, release the Volume button.
- Select the language and keyboard layout.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 3개
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
Where do I get the USB from?
Soto Jaime - 답글
