주요 콘텐츠로 건너뛰기
Refrigerator Handle with No Drills Installation
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 1 단계, 이미지 1/3 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 1 단계, 이미지 2/3 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 1 단계, 이미지 3/3
    • Use a clean sponge or damp lint free cloth to apply the handle to the surface.
    • Soapy water or other mild cleansers may be used to clean the surface from all grease or grime.
    • Preferably use cold or luke warm water.
  2. Refrigerator Handle with No Drills Installation: 2 단계, 이미지 1/3 Refrigerator Handle with No Drills Installation: 2 단계, 이미지 2/3 Refrigerator Handle with No Drills Installation: 2 단계, 이미지 3/3
    • Gently clean the surface of refrigerator where handle will be applied.
    • Ensure the surface is completely dry before application.
  3. Refrigerator Handle with No Drills Installation: 3 단계, 이미지 1/3 Refrigerator Handle with No Drills Installation: 3 단계, 이미지 2/3 Refrigerator Handle with No Drills Installation: 3 단계, 이미지 3/3
    • Clean the bottom of the handle's suction cups with a damp sponge or lint-free towel.
    • Ensure the surface is completely dry up before application.
  4. Refrigerator Handle with No Drills Installation: 4 단계, 이미지 1/1
    • Once both surfaces are dry, place the handle with suction cups facing the refrigerator.
    • Position the handle on the side you would open the refrigerator.
  5. Refrigerator Handle with No Drills Installation: 5 단계, 이미지 1/1
    • Position the handle vertically and at an appropriate height.
    • The height is up to your own personal preference.
  6. Refrigerator Handle with No Drills Installation: 6 단계, 이미지 1/2 Refrigerator Handle with No Drills Installation: 6 단계, 이미지 2/2
    • Apply pressure to both ends of the handle for approximately 15 seconds.
  7. Refrigerator Handle with No Drills Installation: 7 단계, 이미지 1/3 Refrigerator Handle with No Drills Installation: 7 단계, 이미지 2/3 Refrigerator Handle with No Drills Installation: 7 단계, 이미지 3/3
    • Lock the suction cups in place by pushing down on the hatches.
    • Depending on manufacturer, locking the suction handles may differ in method.
  8. Refrigerator Handle with No Drills Installation: 8 단계, 이미지 1/2 Refrigerator Handle with No Drills Installation: 8 단계, 이미지 2/2
    • Slowly release the handle.
    • If handle detaches, repeat steps 4-8 until successful.
결론
Jaskaran Buttar
회원 가입일: 09/29/15
125 평판
안내서 1개 작성함
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015 회원
CPSU-GREEN-F15S10G7
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Help to fix a big hole where the door is holding on door falling off
Joya Hall - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 268
