소개
Diese Anleitung zeigt dir, wie du deine EarPods reinigen kannst
필요한 것
Falls deine EarPods durch Staub, Wachs (oder andere Partikel) verschmutzt sind, folge den Schritten dieser Anleitung, um sie zu reinigen.
Denke daran, deine EarPods 10 Minuten lang trocknen zu lassen.
다른 85명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Matthias Huisken님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 31개
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
With saliva? You &&^&^$ disgusting.
GROSS Saliva? yuck
what the &&^& is wrong with you
