주요 콘텐츠로 건너뛰기
Remington MB4040 Cover Assembly Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 1개 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 2개 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 3개
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 1개 Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 2개
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 1개 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 2개 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 3개
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 1개 Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 2개
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Cover Assembly Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 1개 Remington MB4040 Cover Assembly Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 2개
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
결론
작성자
5다른 기여자 명과 함께
Cameron Carnahan
회원 가입일: 01/20/15
1,082 평판
안내서 6개를 작성함
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G5
3 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 10
전체 시간: 120
