주요 콘텐츠로 건너뛰기
Remington MB4040 Motor Replacement
필요한 것
  1. Remington MB4040 Motor Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 1개 Remington MB4040 Motor Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 2개 Remington MB4040 Motor Replacement, Remove Blade Assembly: 1 단계, 이미지 3개 중 3개
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Motor Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 1개 Remington MB4040 Motor Replacement, Remove Back Cover Hardware: 2 단계, 이미지 2개 중 2개
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 1개 Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 2개 Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 3 단계, 이미지 3개 중 3개
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Motor Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 1개 Remington MB4040 Motor Replacement, Front Cover (cont.): 4 단계, 이미지 2개 중 2개
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Motor Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 1개 Remington MB4040 Motor Replacement, Blade Button Removal: 5 단계, 이미지 2개 중 2개
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Motor Replacement, Remove screws attaching the zoom wheel: 6 단계, 이미지 2개 중 1개 Remington MB4040 Motor Replacement, Remove screws attaching the zoom wheel: 6 단계, 이미지 2개 중 2개
    • Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
  7. Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 1개 Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 2개 Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 7 단계, 이미지 3개 중 3개
    • Remove zoom wheel assembly from housing using fingers.
    • Gently remove zoom wheel assembly because the red and black wires are attached and can easily be broken.
    • This assembly also houses the motor.
    • Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
    • When reassembling, make sure the pins on the slider are aligned inside the grooves of the wheel.
  8. Remington MB4040 Motor Replacement, Wheel removal: 8 단계, 이미지 3개 중 1개 Remington MB4040 Motor Replacement, Wheel removal: 8 단계, 이미지 3개 중 2개 Remington MB4040 Motor Replacement, Wheel removal: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
  9. Remington MB4040 Motor Replacement, Screw Removal: 9 단계, 이미지 1개 중 1개
    • Remove two 3.0 mm PH00 screws from the plastic housing.
  10. Remington MB4040 Motor Replacement, Remove Motor: 10 단계, 이미지 2개 중 1개 Remington MB4040 Motor Replacement, Remove Motor: 10 단계, 이미지 2개 중 2개
    • Remove the motor by carefully prying on the back side of the motor with a spudger.
  11. Remington MB4040 Motor Replacement, Remove Wires: 11 단계, 이미지 3개 중 1개 Remington MB4040 Motor Replacement, Remove Wires: 11 단계, 이미지 3개 중 2개 Remington MB4040 Motor Replacement, Remove Wires: 11 단계, 이미지 3개 중 3개
    • Remove the red and black wires from the motor.
    • To install a new motor, the black and red wires must be soldered on.
결론
작성자
4다른 기여자 명과 함께
Cameron Carnahan
회원 가입일: 01/20/15
1,082 평판
안내서 6개를 작성함
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G5
3 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 28
전체 시간: 3,235
