주요 콘텐츠로 건너뛰기
Remote shutter mod (wired)
필요한 것
    • I will hopefully add more details in the future.
  1. Remote shutter mod (wired), Solder a wire onto a main board: 2 단계, 이미지 3개 중 1개 Remote shutter mod (wired), Solder a wire onto a main board: 2 단계, 이미지 3개 중 2개 Remote shutter mod (wired), Solder a wire onto a main board: 2 단계, 이미지 3개 중 3개
    • Use thin short piece of wire and decide where to put it so it will not be in interference with other components inside assembled camera. The wire will be connected to both sides of the main board.
    • Cut required length of the wire and cut the insulation on its ends.
    • Optional: use some electrical adhesive tape (not very sticky) to hold the wire on the right place while soldering. Watch where are you putting it - not over any small sensitive components
    • Solder the wire to the pins as on the pictures
    • Insert the modified mainboard, put everything to its place and close the camera. Simply reverse the disassembly procedure
  2. Remote shutter mod (wired), Create your custom shutter connector: 4 단계, 이미지 3개 중 1개 Remote shutter mod (wired), Create your custom shutter connector: 4 단계, 이미지 3개 중 2개 Remote shutter mod (wired), Create your custom shutter connector: 4 단계, 이미지 3개 중 3개
    • Use some standard micro USB male connector/cable
    • You can connect some remote shutter to it, or just a button which allows the lines to connect.
    • Pinout as is on the picture
    • sorry for the drawing of microUSB, it looks like half female (because of the inside) and half male. It's supposed to be male connector. But the positions of the pins are correct.
결론
I am not author of the mod, but I will definitely try it in the future.
Pictures are taken from here:
http://przewodnicy.zakopane.pl/rozne/RX1...
Short demonstration is visible here:
https://www.youtube.com/watch?v=3m_yFcxR...
Unfortunately I don't have an option to use any soldering iron or my small tools at the moment, so I will not try it during this year (2017). But it's good to have this guide here.
작성자
1다른 기여자 명과 함께
Matej Cermak
회원 가입일: 10/22/17
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 27
전체 시간: 3,233
