주요 콘텐츠로 건너뛰기
Removal of super-vario 40 braille display
필요한 것
  1. Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: 1 단계, 이미지 1/2 Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: 1 단계, 이미지 2/2
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Removal of super-vario 40 braille display: 2 단계, 이미지 1/3 Removal of super-vario 40 braille display: 2 단계, 이미지 2/3 Removal of super-vario 40 braille display: 2 단계, 이미지 3/3
    • Remove the plastic cover, paper and chipset.
  3. Removal of super-vario 40 braille display: 3 단계, 이미지 1/3 Removal of super-vario 40 braille display: 3 단계, 이미지 2/3 Removal of super-vario 40 braille display: 3 단계, 이미지 3/3
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Removal of super-vario 40 braille display: 4 단계, 이미지 1/3 Removal of super-vario 40 braille display: 4 단계, 이미지 2/3 Removal of super-vario 40 braille display: 4 단계, 이미지 3/3
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Removal of super-vario 40 braille display: 5 단계, 이미지 1/3 Removal of super-vario 40 braille display: 5 단계, 이미지 2/3 Removal of super-vario 40 braille display: 5 단계, 이미지 3/3
    • Remove the connector delicately.
  6. Removal of super-vario 40 braille display: 6 단계, 이미지 1/2 Removal of super-vario 40 braille display: 6 단계, 이미지 2/2
    • when you put it back together make sure mechanical cells are connected correctly
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sisyphe
회원 가입일: 07/29/13
350 평판
안내서 2개 작성하였습니다
댓글 2개
great guide!  how can I repair a VarioUltra 20?  are the procedures similar?  the device has a problem at point 4 of the sixth cell, the point moves unsteadily, should I replace this whole cell or is it possible to just repair point 4, which is defective?
marcusvinicioslira - 답글
which professional will likely be able to repair a braille display?  should I look for an electrical engineer or other professional?  I'm blind, I don't repair electronics, but I have a defective braille display that needs to be repaired.  I live in a country where there are no companies capable of repairing this product.  I do not know what to think.  sending the product to a specialized company in another country is very expensive for me.
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 16
전체 시간: 1,005
