주요 콘텐츠로 건너뛰기
소개
To begin, make sure to remove the battery before doing anything else.
  1. Make sure that the computer is turned off and is disconnected from external power source.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment. These screws hold the hard drive tray into the hard drive compartment.
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Slide the hard drive tray out of the hard drive compartment.
    • Slide the hard drive tray out of the hard drive compartment.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Malik Shahbal
회원 가입일: 2010년 10월 05일
471 평판
안내서 5개 작성하였습니다
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 회원
CPSU-MANESS-F10S22G5
4 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 26
전체 시간: 19,463
