주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Remove Dislodged Plug Parts
필요한 것
  1. Remove Dislodged Plug Parts, Remove Left Ear Cushion: 1 단계, 이미지 2개 중 1개 Remove Dislodged Plug Parts, Remove Left Ear Cushion: 1 단계, 이미지 2개 중 2개
    • Place the headphones down with ear cushions facing you
    • Cushions are held in by small tabs along the perimeter. Remove by hand
  2. Remove Dislodged Plug Parts, Remove Left Driver Pad: 2 단계, 이미지 2개 중 1개 Remove Dislodged Plug Parts, Remove Left Driver Pad: 2 단계, 이미지 2개 중 2개
    • Pad is held in by two pieces of double-sided tape. You only need to peel back the left piece, as shown
    • Be careful to avoid tearing the pad
  3. Remove Dislodged Plug Parts, Remove Left Backplate: 3 단계, 이미지 2개 중 1개 Remove Dislodged Plug Parts, Remove Left Backplate: 3 단계, 이미지 2개 중 2개
    • First, remove the two small philips screws securing the backplate to the body
    • Turn the headphones over and carefully wiggle the backplate away from the body. Use soft plastic tools if necessary to avoid scratching the plate
  4. Remove Dislodged Plug Parts, Remove Plug Circuit Board: 4 단계, 이미지 2개 중 1개 Remove Dislodged Plug Parts, Remove Plug Circuit Board: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two small, shorter philips screws securing the board to the body
    • The board is now held in by vinyl tape (black) and two ribbon cables
    • If you are just removing broken plug pieces, do not disconnect these ribbon cables - be careful not to damage them! Instead, simply lift the board enough to poke tweezers or similar through the plug to dislodge broken bits
    • If replacing the plug, disconnect the ribbon cables (one is soldered in place) from the circuit board and replace the board
결론
Reassembly is the reverse of disassembly - no surprises. Optionally, replace your ear cushions, pads, or double sided tape in the process.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Pangburn
회원 가입일: 12/31/20
280 평판
안내서 1개를 작성함
4가이드 댓글
This guide was also useful to push back the pins of the headphone jack, as the plug got loose with the Gaming mic attachment.
Albert - 답글 공유
Does that work for a lose 2.5 mm plug that it’s not making correct contact?
Marcos Ruiz - 공유
Where can i buy the spare parts ?
Term - 답글 공유
Where do we even get another receiver plug?
George “calfilmmaker” - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 88
전체 시간: 8,766
