주요 콘텐츠로 건너뛰기
소개
This guide shows how to separate the GameCube's optical drive assembly from the motherboard.
부품
지정된 부품이 없습니다.
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 3/3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 3/3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: 3 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: 3 단계, 이미지 2/2
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  4. Remove Nintendo GameCube Optical Drive Assembly: 4 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly: 4 단계, 이미지 2/2
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  5. Remove Nintendo GameCube Optical Drive Assembly: 5 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly: 5 단계, 이미지 2/2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  6. Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 3/3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
결론
dcarlin
회원 가입일: 2009년 11월 05일
295 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 회원
CPSU-MANESS-F09S6G2
4 회원들
안내서 37개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 24
전체 시간: 4,351
