주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Remove Nintendo GameCube Optical Drive Assembly
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 1 단계, 이미지 3/3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly: 2 단계, 이미지 3/3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: 3 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: 3 단계, 이미지 2/2
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red wire)
  4. Remove Nintendo GameCube Optical Drive Assembly: 4 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly: 4 단계, 이미지 2/2
    • Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal).
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  5. Remove Nintendo GameCube Optical Drive Assembly: 5 단계, 이미지 1/2 Remove Nintendo GameCube Optical Drive Assembly: 5 단계, 이미지 2/2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
  6. Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 1/3 Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 2/3 Remove Nintendo GameCube Optical Drive Assembly: 6 단계, 이미지 3/3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
결론
dcarlin
회원 가입일: 11/05/09
301 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 회원
CPSU-MANESS-F09S6G2
4 회원들
안내서 45개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,372
