주요 콘텐츠로 건너뛰기
Remove and clean the Whirlpool dishwasher spray arm
필요한 것
  1. Remove and clean the Whirlpool dishwasher spray arm, Spray arm: 1 단계, 이미지 1/2 Remove and clean the Whirlpool dishwasher spray arm, Spray arm: 1 단계, 이미지 2/2
    • Turn off the dishwasher.
  2. Remove and clean the Whirlpool dishwasher spray arm: 2 단계, 이미지 1/3 Remove and clean the Whirlpool dishwasher spray arm: 2 단계, 이미지 2/3 Remove and clean the Whirlpool dishwasher spray arm: 2 단계, 이미지 3/3
    • Remove the lower rack.
  3. Remove and clean the Whirlpool dishwasher spray arm: 3 단계, 이미지 1/1
    • Locate the lower spray arm.
  4. Remove and clean the Whirlpool dishwasher spray arm: 4 단계, 이미지 1/3 Remove and clean the Whirlpool dishwasher spray arm: 4 단계, 이미지 2/3 Remove and clean the Whirlpool dishwasher spray arm: 4 단계, 이미지 3/3
    • Detach the lower spray arm by rotating the base counterclockwise.
  5. Remove and clean the Whirlpool dishwasher spray arm: 5 단계, 이미지 1/3 Remove and clean the Whirlpool dishwasher spray arm: 5 단계, 이미지 2/3 Remove and clean the Whirlpool dishwasher spray arm: 5 단계, 이미지 3/3
    • Detach the top spray arm by rotating the base clockwise.
  6. Remove and clean the Whirlpool dishwasher spray arm: 6 단계, 이미지 1/2 Remove and clean the Whirlpool dishwasher spray arm: 6 단계, 이미지 2/2
    • Clean the spray arm with warm soapy water and a soft brush.
  7. Remove and clean the Whirlpool dishwasher spray arm: 7 단계, 이미지 1/3 Remove and clean the Whirlpool dishwasher spray arm: 7 단계, 이미지 2/3 Remove and clean the Whirlpool dishwasher spray arm: 7 단계, 이미지 3/3
    • Rinse thoroughly and reattach the spray arm to the dishwasher.
    • The longer spray arm goes on the bottom and the shorter one on the top.
  8. Remove and clean the Whirlpool dishwasher spray arm: 8 단계, 이미지 1/1
    • Run a cycle with hot water and a dishwasher cleaner to further clean the interior.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Eduardo Mola
회원 가입일: 01/16/23
175 평판
안내서 1개 작성함
York University, Team N-9, Morris Winter 2023 York University, Team N-9, Morris Winter 2023 회원
YORK-MORRIS-W23SNG9
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 70
30일 전: 409
전체 시간: 6,034
