주요 콘텐츠로 건너뛰기
Remove the Write Protect Screw
필요한 것
  1. Remove the Write Protect Screw, Remove the rubber pads: 1 단계, 이미지 1/2 Remove the Write Protect Screw, Remove the rubber pads: 1 단계, 이미지 2/2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Remove the Write Protect Screw, Removing the bottom panel: 2 단계, 이미지 1/3 Remove the Write Protect Screw, Removing the bottom panel: 2 단계, 이미지 2/3 Remove the Write Protect Screw, Removing the bottom panel: 2 단계, 이미지 3/3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Remove the Write Protect Screw, Pop it open: 3 단계, 이미지 1/2 Remove the Write Protect Screw, Pop it open: 3 단계, 이미지 2/2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 4 단계, 이미지 1/2 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 4 단계, 이미지 2/2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - 답글
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - 답글
    How to check if screw is already removed or not? By not opening its back.
    Abdullah Ishfaq - 답글
결론
다른 15명이 해당 안내서를 완성하였습니다.
Kevin Fessler
회원 가입일: 04/16/16
1,770 평판
안내서 4개 작성하였습니다
댓글 4개
removing this will allow me to boot and install windows?
john Akday - 답글
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy -
Acer R752TN write protect screw location?
Fredrik Løvås - 답글
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 135
30일 전: 586
전체 시간: 36,048
