주요 콘텐츠로 건너뛰기
Removing 1994-2001 Acura Integra Center Console
필요한 것
  1. Removing 1994-2001 Acura Integra Center Console, Center Console: 1 단계, 이미지 1/2 Removing 1994-2001 Acura Integra Center Console, Center Console: 1 단계, 이미지 2/2
    • Remove the two Phillips screws at the very rear of the center console near the floor.
  2. Removing 1994-2001 Acura Integra Center Console: 2 단계, 이미지 1/2 Removing 1994-2001 Acura Integra Center Console: 2 단계, 이미지 2/2
    • Insert a small flathead screwdriver into the notch at the driver's side rear corner of the screw cover directly below the parking brake lever and pry it off.
    • Remove the two Phillips screws that were underneath the screw cover.
  3. Removing 1994-2001 Acura Integra Center Console: 3 단계, 이미지 1/2 Removing 1994-2001 Acura Integra Center Console: 3 단계, 이미지 2/2
    • Grab the bottom of the rear portion of the console and lift up and away from the front of the car.
    • Remove the rear portion of the center console.
  4. Removing 1994-2001 Acura Integra Center Console: 4 단계, 이미지 1/2 Removing 1994-2001 Acura Integra Center Console: 4 단계, 이미지 2/2
    • Pull the ash tray out from the center console until it stops.
    • Push down on the metal plate at the top of the ash tray and continue to pull the tray out until it is completely removed.
  5. Removing 1994-2001 Acura Integra Center Console: 5 단계, 이미지 1/3 Removing 1994-2001 Acura Integra Center Console: 5 단계, 이미지 2/3 Removing 1994-2001 Acura Integra Center Console: 5 단계, 이미지 3/3
    • Remove two Phillips screws from behind the ash tray.
    • Remove the lower portion of the console that contains the cigarette lighter from the rest of the center console.
    • Disconnect the electrical connector for the cigarette lighter by first depressing the tab on top, and then pulling directly out of the socket.
  6. Removing 1994-2001 Acura Integra Center Console: 6 단계, 이미지 1/3 Removing 1994-2001 Acura Integra Center Console: 6 단계, 이미지 2/3 Removing 1994-2001 Acura Integra Center Console: 6 단계, 이미지 3/3
    • Remove four Phillips screws that hold the side pieces of the front portion of the console in place.
    • Two below the radio pocket.
    • Two on the faces of the side pieces, one on either side.
  7. Removing 1994-2001 Acura Integra Center Console: 7 단계, 이미지 1/2 Removing 1994-2001 Acura Integra Center Console: 7 단계, 이미지 2/2
    • Remove the shift knob by unscrewing it counter-clockwise.
    • Lift the front portion of the center console up and away from the front of the car.
    • It may be necessary to pull the emergency brake handle up further to create enough room to remove the front portion of the center console.
결론
다른 8명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,493 평판
안내서 127개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 19,133
