주요 콘텐츠로 건너뛰기
Removing 1997-2003 Pontiac Grand Prix GT Back Seat
  1. Removing 1997-2003 Pontiac Grand Prix GT Back Seat, Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 1 단계, 이미지 1/1
    • Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
  2. Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 2 단계, 이미지 1/1
    • Pull/lift the tab/lever on each side to release the seat.
  3. Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 3 단계, 이미지 1/1
    • Lift up and remove the seat.
  4. Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 4 단계, 이미지 1/2 Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 4 단계, 이미지 2/2
    • Clean the seat or do whatever it is you wish to do.
  5. Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 5 단계, 이미지 1/3 Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 5 단계, 이미지 2/3 Removing 1997-2003 Pontiac Grand Prix GT Back Seat: 5 단계, 이미지 3/3
    • Put the seat back on.
    • As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back.
    • As shown in the second image is a hook that goes into the base of the backseat.
    • The third image is of the tab that the hook on the seat goes into.
    • When you line up the hooks and tabs, push down hard. You will hear a click when the hooks are fitted into the tabs.
    • And there, your seat has been taken out and put back in! Good job!
결론
Your seat has now been taken out and put back in. Not hard, eh?
다른 4명이 해당 안내서를 완성하였습니다.
Scratchitory
회원 가입일: 04/25/13
1,136 평판
안내서 3개 작성하였습니다
댓글 한 개
Will back seats out of a 2004 or 5 grand Prix gt fit in 2003 SS Monte Carlo. Help please
Perry monahan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 37
전체 시간: 10,929
