주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing Aftermarket Vehicle Window Tinting
필요한 것
  1. Removing Aftermarket Vehicle Window Tinting, Before Photos: 1 단계, 이미지 3개 중 1개 Removing Aftermarket Vehicle Window Tinting, Before Photos: 1 단계, 이미지 3개 중 2개 Removing Aftermarket Vehicle Window Tinting, Before Photos: 1 단계, 이미지 3개 중 3개
    • This is what your window will look like before.
    • And the third photo shows what it will look like after!
    댓글 쓰기
  2. Removing Aftermarket Vehicle Window Tinting: 2 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 2 단계, 이미지 2개 중 2개
    • Roll down the window about 1/4 of the way so you can start to remove the tint from the top.
    댓글 쓰기
  3. Removing Aftermarket Vehicle Window Tinting: 3 단계, 이미지 3개 중 1개 Removing Aftermarket Vehicle Window Tinting: 3 단계, 이미지 3개 중 2개 Removing Aftermarket Vehicle Window Tinting: 3 단계, 이미지 3개 중 3개
    • Heat the area with a heat gun at the window's edge.
    • Start by using the low setting on the heat gun to gradually heat the surface. After the area has warmed up, you can switch to high heat to make it easier to remove the film.
    • Use the razor blade to peel a small area of the tint film up.
    댓글 쓰기
  4. Removing Aftermarket Vehicle Window Tinting: 4 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 4 단계, 이미지 2개 중 2개
    • Once you've peeled enough with the razor blade to use your fingers, heat the area, then peel with your fingers.
    • Don't pull with your fingers and heat the area with the gun simultaneously. You'll burn yourself.
    • Heat the film angling the heat gun up. This will ensure that the film will not rip easily.
    댓글 쓰기
  5. Removing Aftermarket Vehicle Window Tinting: 5 단계, 이미지 1개 중 1개
    • When you've pulled enough film off so that you don't burn your fingers while simultaneously pulling, use a back-and-forth motion with the heat gun along the area where the film is still on the window while pulling on the film. (See next step)
    댓글 쓰기
    • How to heat the area with the heat gun.
    댓글 쓰기
  6. Removing Aftermarket Vehicle Window Tinting: 7 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 7 단계, 이미지 2개 중 2개
    • Once you have removed the film from the top of the window, you can roll up the window.
    • Continue doing a back-and-forth motion and pulling on the film until all of the film comes off.
    • If the film rips, no worries. Just continue. You can heat up those sections and remove them later.
    댓글 쓰기
  7. Removing Aftermarket Vehicle Window Tinting: 8 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 8 단계, 이미지 2개 중 2개
    • Once you have removed all of the film, spray the window with glass cleaner and clean the window with either a rag or paper towel.
    댓글 쓰기
  8. Removing Aftermarket Vehicle Window Tinting: 9 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 9 단계, 이미지 2개 중 2개
    • For areas where some residue is still on the window, spray the area with glass cleaner and use the razor blade to scrape the area to remove the residue.
    • For really tough residue, use Goo Gone in lieu of glass cleaner.
    댓글 쓰기
  9. Removing Aftermarket Vehicle Window Tinting: 10 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting: 10 단계, 이미지 2개 중 2개
    • First photo: Before
    • Second photo: After
    댓글 쓰기
  10. Removing Aftermarket Vehicle Window Tinting, Before and After: 11 단계, 이미지 2개 중 1개 Removing Aftermarket Vehicle Window Tinting, Before and After: 11 단계, 이미지 2개 중 2개
    댓글 쓰기
결론
You are finished! Repeat the steps in this guide for every window you wish to remove the tinting.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
S.I. Dalton
회원 가입일: 09/05/24
1,728 평판
안내서 4개를 작성함
Apple fan boys Apple fan boys 회원
Community
57 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 54
전체 시간: 752
