주요 콘텐츠로 건너뛰기
Removing Audio Technica ATH-AD500 Foam Disks
필요한 것
  1. Removing Audio Technica ATH-AD500 Foam Disks, Speaker Assembly: 1 단계, 이미지 1/1
    • Remove the ear pads by peeling them away from the grill.
  2. Removing Audio Technica ATH-AD500 Foam Disks: 2 단계, 이미지 1/1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Removing Audio Technica ATH-AD500 Foam Disks: 3 단계, 이미지 1/1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: 4 단계, 이미지 1/2 Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: 4 단계, 이미지 2/2
    • Remove the foam disk from the grill by peeling it away from the grill.
    • During reassembly, make sure that the speaker is angled into your ear canal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Melanie Reis
회원 가입일: 01/11/13
227 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 회원
CPSU-FORTE-W13S17G19
6 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 2,133
