소개
We will unscrew the bottom faceplate, then remove the base to access the internal components.
필요한 것
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
거의 끝나갑니다!
결론
다른 9명이 해당 안내서를 완성하였습니다.
