주요 콘텐츠로 건너뛰기
Removing Canon PowerShot A550 Front and Back Covers
필요한 것
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 1 단계, 이미지 1/3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 1 단계, 이미지 2/3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 1 단계, 이미지 3/3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: 2 단계, 이미지 1/1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: 3 단계, 이미지 1/1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: 4 단계, 이미지 1/2 Removing Canon PowerShot A550 Front and Back Covers: 4 단계, 이미지 2/2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: 5 단계, 이미지 1/1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: 6 단계, 이미지 1/3 Removing Canon PowerShot A550 Front and Back Covers: 6 단계, 이미지 2/3 Removing Canon PowerShot A550 Front and Back Covers: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: 7 단계, 이미지 1/1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Shaelyn Thomas
회원 가입일: 04/19/11
332 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 회원
CPSU-REGAN-S11S8G6
4 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 4,336
