메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Flip the keyboard upside down so the bottom is angled towards you.
    • Flip the keyboard upside down so the bottom is angled towards you.
  2. Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
    • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Remove the bottom panel by lifting the bottom panel up and outward from yourself.
    • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  5. Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
    • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
    • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jimmy Winne
회원 가입일: 2012년 10월 04일
446 평판
안내서 6개 작성하였습니다
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G16
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 9
전체 시간: 1,379
