소개
This guide will show you how to remove the back cover of your device.
부품
부품은 필요하지 않습니다.
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
거의 끝나갑니다!
결론
