주요 콘텐츠로 건너뛰기
Removing DVD Drive from Acer Aspire 5100
필요한 것
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: 1 단계, 이미지 1/2 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: 1 단계, 이미지 2/2
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: 2 단계, 이미지 1/1
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: 3 단계, 이미지 1/2 Removing DVD Drive from Acer Aspire 5100: 3 단계, 이미지 2/2
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: 4 단계, 이미지 1/2 Removing DVD Drive from Acer Aspire 5100: 4 단계, 이미지 2/2
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: 5 단계, 이미지 1/1
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
결론
To reassemble, follow above steps in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
luis
회원 가입일: 04/21/10
167 평판
안내서 1개 작성함
Cal Poly, Team 18-66, Johann Spring 2010 Cal Poly, Team 18-66, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G66
5 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 22
전체 시간: 2,790
