주요 콘텐츠로 건너뛰기
Removing Dell Inspiron 1150 Battery
  1. Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 1/3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 2/3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 3/3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Teja
회원 가입일: 04/27/10
98 평판
안내서 3개 작성하였습니다
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 회원
CPSU-MANESS-S10S16G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 10,868
