주요 콘텐츠로 건너뛰기
Removing Dell Inspiron 1150 Mini Wireless PCI Card
필요한 것
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 1 단계, 이미지 1/3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 1 단계, 이미지 2/3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 1 단계, 이미지 3/3
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: 2 단계, 이미지 1/2 Removing Dell Inspiron 1150 Mini Wireless PCI Card: 2 단계, 이미지 2/2
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: 3 단계, 이미지 1/1
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Teja
회원 가입일: 04/27/10
98 평판
안내서 3개 작성하였습니다
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 회원
CPSU-MANESS-S10S16G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 18
전체 시간: 5,909
