주요 콘텐츠로 건너뛰기
Removing Dell Inspiron 1150 Optical drive
필요한 것
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 1/3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 2/3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 3/3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 2 단계, 이미지 1/2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 2 단계, 이미지 2/2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: 3 단계, 이미지 1/2 Removing Dell Inspiron 1150 Optical drive: 3 단계, 이미지 2/2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 4 단계, 이미지 1/3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 4 단계, 이미지 2/3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 4 단계, 이미지 3/3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
결론
Daniel
회원 가입일: 04/25/10
87 평판
안내서 2개 작성하였습니다
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 회원
CPSU-MANESS-S10S16G2
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 18
전체 시간: 5,905
