주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
부품
지정된 부품이 없습니다.
  1. Turn the laptop upside down and  locate the panel labeled C. Unscrew the single screw holding the cover in place. lift up the cover and remove it to exposed the Wireless MiniPCI Card.
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • lift up the cover and remove it to exposed the Wireless MiniPCI Card.
  2. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  3. Using a plastic spudger or similar, gently pry the grey and black wires off. The grey and black wires are the antenna wires so be careful not to damage them
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  4. Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Teja
회원 가입일: 2010년 04월 27일
98 평판
안내서 3개 작성하였습니다
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 회원
CPSU-MANESS-S10S16G2
4 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 5,583
