주요 콘텐츠로 건너뛰기
Removing Dell Inspiron 15-7537 Bottom Cover
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Removing Dell Inspiron 15-7537 Bottom Cover, Bottom Case: 1 단계, 이미지 1/1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Removing Dell Inspiron 15-7537 Bottom Cover: 2 단계, 이미지 1/1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Removing Dell Inspiron 15-7537 Bottom Cover: 3 단계, 이미지 1/1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Removing Dell Inspiron 15-7537 Bottom Cover, Battery: 4 단계, 이미지 1/1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Removing Dell Inspiron 15-7537 Bottom Cover: 5 단계, 이미지 1/1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Removing Dell Inspiron 15-7537 Bottom Cover, Hard Drive: 6 단계, 이미지 1/1
  7. Removing Dell Inspiron 15-7537 Bottom Cover, Remove the WiFi Card: 7 단계, 이미지 1/2 Removing Dell Inspiron 15-7537 Bottom Cover, Remove the WiFi Card: 7 단계, 이미지 2/2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  8. Removing Dell Inspiron 15-7537 Bottom Cover: 8 단계, 이미지 1/1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  9. Removing Dell Inspiron 15-7537 Bottom Cover: 9 단계, 이미지 1/1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
  10. Removing Dell Inspiron 15-7537 Bottom Cover, Removing the Keyboard: 10 단계, 이미지 1/1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  11. Removing Dell Inspiron 15-7537 Bottom Cover: 11 단계, 이미지 1/1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  12. Removing Dell Inspiron 15-7537 Bottom Cover: 12 단계, 이미지 1/1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  13. Removing Dell Inspiron 15-7537 Bottom Cover: 13 단계, 이미지 1/3 Removing Dell Inspiron 15-7537 Bottom Cover: 13 단계, 이미지 2/3 Removing Dell Inspiron 15-7537 Bottom Cover: 13 단계, 이미지 3/3
    • Take the keyboard off the palm rest assembly.
  14. Removing Dell Inspiron 15-7537 Bottom Cover, Bottom Cover: 14 단계, 이미지 1/1
    • Unscrew the two black 5 mm screws underneath the keyboard using a Phillips head screwdriver.
  15. Removing Dell Inspiron 15-7537 Bottom Cover: 15 단계, 이미지 1/2 Removing Dell Inspiron 15-7537 Bottom Cover: 15 단계, 이미지 2/2
    • Flip the computer and remove the two silver 5 mm screws on the corners of the base cover with the Phillips head screwdriver.
  16. Removing Dell Inspiron 15-7537 Bottom Cover: 16 단계, 이미지 1/1
    • Unscrew the three black 5 mm screws with the Phillips head screwdriver.
  17. Removing Dell Inspiron 15-7537 Bottom Cover: 17 단계, 이미지 1/2 Removing Dell Inspiron 15-7537 Bottom Cover: 17 단계, 이미지 2/2
    • Remove the three silver 2 mm screws (with large flat circular heads) from where the battery was taken out with the Phillips head screwdriver.
  18. Removing Dell Inspiron 15-7537 Bottom Cover: 18 단계, 이미지 1/2 Removing Dell Inspiron 15-7537 Bottom Cover: 18 단계, 이미지 2/2
    • Place a plastic spudger underneath the base cover and move it along the outside of the cover. Once the cover is disconnected lift the off the base cover.
    • To fully take off the base cover the wires that connect to the WiFi card need to be pulled off and pulled through its hole in the base cover
결론
Jean Whitmore
회원 가입일: 01/22/15
984 평판
안내서 7개 작성하였습니다
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 회원
CPSU-MANESS-W15S18G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 124
