주요 콘텐츠로 건너뛰기
Removing Dell Inspiron 530 Processor
필요한 것
  1. Removing Dell Inspiron 530 Processor, Side Panel: 1 단계, 이미지 1/1
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Removing Dell Inspiron 530 Processor: 2 단계, 이미지 1/1
    • Slide the side panel towards the back and remove.
  3. Removing Dell Inspiron 530 Processor, Removing Processor: 3 단계, 이미지 1/1
    • Locate the processor's heat sink and fan.
  4. Removing Dell Inspiron 530 Processor: 4 단계, 이미지 1/1
    • Remove the fan's power cable from the motherboard.
  5. Removing Dell Inspiron 530 Processor: 5 단계, 이미지 1/1
    • Locate and unscrew the four Phillips #0 screws at the corners of the fan.
    • The screws will not come out completely.
  6. Removing Dell Inspiron 530 Processor: 6 단계, 이미지 1/1
    • Remove the fan and heat sink.
  7. Removing Dell Inspiron 530 Processor: 7 단계, 이미지 1/1
    • Gently press down and release the silver lever.
  8. Removing Dell Inspiron 530 Processor: 8 단계, 이미지 1/1
    • Open the metal casing over the processor.
  9. Removing Dell Inspiron 530 Processor: 9 단계, 이미지 1/1
    • Gently lift up the processor, holding by the edges only.
결론
Note: For reassembly on step seven, make sure the corner of the processor with the gold triangle is pointing towards the release lever.
다른 14명이 해당 안내서를 완성하였습니다.
James Aldag
회원 가입일: 10/20/11
402 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 회원
CPSU-REGAN-F11S6G8
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 23
전체 시간: 8,974
