주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Removing Fender Frontman 15r Back panel
필요한 것
  1. Removing Fender Frontman 15r Back panel, Back panel: 1 단계, 이미지 1개 중 1개
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: 2 단계, 이미지 1개 중 1개
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: 3 단계, 이미지 1개 중 1개
    • Once the top is separated, use your hand to remove the back panel from the unit.
결론
작성자
4다른 기여자 명과 함께
Greg Sawers
회원 가입일: 09/27/12
91 평판
안내서 3개를 작성함
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 회원
CPSU-REGAN-F12S24G30
5 회원들
안내서 7개를 작성함
2가이드 댓글
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - 답글 공유
The way to get the electronics out is by removing the front panel, because removing them through the back is not possible because of the reverb unit. In case you need to disassemble a Fender frontman 15R, have a look at https://www.youtube.com/watch?v=ioQnwjgv...
repairchannel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 68
전체 시간: 7,284
