주요 콘텐츠로 건너뛰기
소개
Removing front panel to replace main LCD or small display screen.
부품
지정된 부품이 없습니다.
  1. Using the plastic opening tool, pry off the top faceplate.
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Using the T6 Torx Screwdriver remove all 4 small screws.
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Remove silver plate from phone.
    • Remove silver plate from phone.
  4. Using the spudger remove the plastic camera casing
    • Using the spudger remove the plastic camera casing
  5. Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Use Spudger or hands to detach flex cable from front screen logic board
    • Use Spudger or hands to detach flex cable from front screen logic board
결론
Cecilia
회원 가입일: 2010년 04월 11일
1 평판
안내서 3개 작성하였습니다
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G96
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,819
