주요 콘텐츠로 건너뛰기
Removing HP Compaq dx2000MT CPU Cooler
필요한 것
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: 1 단계, 이미지 1/1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: 2 단계, 이미지 1/2 Removing HP Compaq dx2000MT CPU Cooler: 2 단계, 이미지 2/2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: 3 단계, 이미지 1/3 Removing HP Compaq dx2000MT CPU Cooler: 3 단계, 이미지 2/3 Removing HP Compaq dx2000MT CPU Cooler: 3 단계, 이미지 3/3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: 4 단계, 이미지 1/3 Removing HP Compaq dx2000MT CPU Cooler: 4 단계, 이미지 2/3 Removing HP Compaq dx2000MT CPU Cooler: 4 단계, 이미지 3/3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: 5 단계, 이미지 1/2 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: 5 단계, 이미지 2/2
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: 6 단계, 이미지 1/2 Removing HP Compaq dx2000MT CPU Cooler: 6 단계, 이미지 2/2
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: 7 단계, 이미지 1/2 Removing HP Compaq dx2000MT CPU Cooler: 7 단계, 이미지 2/2
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Logan Pace
회원 가입일: 10/12/11
2,251 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 5,509
